Zipp is proud the SL Speed Carbon Water Bottle, designed with the same meticulous attention to detail as Zipp's wheels. The result is worry-free hydration with that distinctive Zipp style and efficiency. The SL Speed carbon bottle cage features an all-new ultra-light (18g) design engineered for flexibility and strength. Optimized for both side and direct bottle entry the SL Speed cage provides easy access to hydration, especially on smaller frames and those with tight angles. Thin-but-strong arms flex for easy bottle insertion and removal, at any angle. Worry free hydration when speed matters. Material : Unidirectional carbon fiber Weight : 18g without bolts Color Black
