Constructed of tough ABS plastic. All seams are solvent welded and have a 1 " mounting flange for easy installation. Most tanks are available with a 3" spigot fitting and level sensors pre-installed. Available with drain located on side, bottom, left end, right end, center end or recessed drain. Measure existing tank, note drain position and call for further information and ordering.
